67 Camaro
What part pushes the dash brake light switch closed?
I have the switch mounted but nothing pushes it closed. Is there a small bracket that attaches to the parking brake pedal assembly that may be missing from my assembly?
The switch is the one with tan wire that goes to the master cyl block
The brake light on dash does not work. I will check to see if PO just pulled the bulb but nothing closes the switch that is mounted to parking brake pedal assembly
would it be this?
https://www.rickscamaros.com/camaro...clip-1967-1969.html?crosssell=Product_Related
would it be this?
