1 - 15 of 15 Posts
Shawn Lemans Blue 1969 Camaro LS3, TKO 600
Does anyone know exactly what this is and where does it go? I think it is a window part.
278736
Looks like window or door latch part. Also looks like it broken at the top?
Discussion Starter · #3 ·
I don’t thin it is broken, it’s just the angle of the picture.
278741
nope…. Looks like a stop but I can’t find a pic. I think it bolts to a regulator?
Don
Reactions: yellow69RS
68 Camaro SS/RS, 454 BB 4 speed, 3.73 Posi, new paint, motor mods , trans and diff assembly. 2" Drop
My guess is it is a cable guide/hold down for the dash heater vent controls.
Discussion Starter · #8 · (Edited)
I took pictures of where it goes on the front regulator but no longer know how to post them here.
Jeff
If the picture is on your computer, click the three dots in the upper right hand corner of your post. Click EDIT. When post comes up, click the paper clip in the center of the menu below the post. Then click "Photo library", when photos come up, select the picture you want. When you tap the picture, it should say "add". That will add the picture to your post.
Discussion Starter · #12 ·
Jeff
Thanks Jeff a picture would be helpful.
The bolt head and locator top center in first pic the bracket from the other side of regulator in second. they are right and left so not sure if I've got the same side as you but you get the idea on how it goes.
Discussion Starter · #14 ·
1 - 15 of 15 Posts
