21 - 23 of 23 Posts
Yes - definitely need To put a dial indicator on the axle. Sounds to me like a bad axle with you moving the drum 2 studs and the tight spot moving. If it always lines up with the same stud the axle is not true and is probably also causing some vibration.
OP
have you checked axle flange run out on the problem side, PS rear?
I want him to pull the parking brake strut out and put it all back together and adjust it. Then tell us if the shoes sit on the pin the way they are supposed to. Completely takes the parking brake out of the equation for holding the shoes out.
Jeff
21 - 23 of 23 Posts
