1 - 8 of 8 Posts
Hey guys, (and gals.)
Please help me out of a jam.
I need some digital imagery sent to my email account. Help. Help. Help.
I need photos that show the difference between the Muncie M20 and the Muncie M-21, in detail!!!
Photos of both if possible. Help.
69 RS-SS
[This message has been edited by Scoop69RS-SS (edited 11-06-2001).]
I hope that i read your post correctly. The outside will look the same. It's the gears inside that make them M-20, M-21, M-22. The only other thing is the stamping on the outside of the case by the assembly date. A=M20, B=M21, C=M22. The ABC stamping, however, was only started mid-run for 1969.
You could get pics of the shafts. Those look different. Jerry MacNeish's The definitive Z28 and SS-396 book has pics.
[This message has been edited by Silver69 (edited 11-06-2001).]
The M-20 has 2 grooves on the input shaft and the M-21 has only one. There is still no guarantee on what the trans is though without counting the teeth on the inside unless it is a later model with a letter code on the casting. Of course someone could have still swapped the guts into one of these but is probably unlikely.
Actually since 1966 the M-20 and M-21 also carried the 1" countergear pin. The only true way to tell is to count the teeth. the M-20 (1963-65) input shaft teeth on the gear (not splines) was 24 teeth. The countergear shaft teeth were 17, 19, 22 and 29. 1966-74 was 21 on the input and 17,19,22 and 25 on the countergear. The M-21 was 26 teeth on the input 17,19,22,27 on the countergear. The M-22 had the same teeth count as the M-21 but the helix angle of the gears is different. Hope this helps
You can put the trans in first gear and rotate the tailshaft 1 revoluton while counting the number of revolutions on the input shaft. This will give you the approximate first gear. Match this up with the first gear for either the M-20 or M-21/22. I know the M-20 has a lower first and I think it is aroung 2.5 vs 2.2 for the M-21/22. If you think it is the M21/22 you can take the side cover off to verify if the gears are straight cut.
Kent
1 - 8 of 8 Posts
