Here is another pic but on this one the top alternator bracket is not correct and the PVC valve is in the wrong location.
Roger
Roger - are you using exhaust manifold gaskets? If so, what is the source? Everything I've seen is generic SBC and requires trimming, and I'm not that great with the snips. Thanks
When I rebuilt my engine I used a Fel-Por gasket set mainly because of the head gaskets. The manifold gaskets didn't need trimed. If yours was like mine originally there wasn't any manifold gaskets. I was debaiting to use gaskets or not. I ended up installing the gaskets.
Roger
