67 Camaro, new BPE 383 (one piece rear main), new Lakewood bellhousing, Richmond Super T10 transmission.
When I removed the transmission from the old motor, I inspected the input shaft for wear/slop. Looking at the pilot shaft and the marks left behind from the pilot bushing, it appeared that there was at least .500" of space where the pilot shaft wasn't contacting anything. While buying parts to put everything back together, I picked up an extra long pilot bushing to see if it would fit and give me more bushing/shaft contact. I know they're typically used when torque plates or engine mounts are added between the bellhousing and block, but if it fits my application, more contact between the shaft and bushing has to be better, right? The long bushing measures 1.012". If it doesn't work, I'll pull it and put a standard bushing in it.
I took a bunch of measurements last night and everything measured okay, so I decided to do a test fit before installing the clutch. I drove the bushing in until it hit bottom, bolted the bellhousing to the trans, and slid the trans/bellhousing on to the block. The bellhousing slid right up tight to the block, so I bolted it on. I reached in through the shift fork opening and can spin the input shaft with a thumb/index finger, so everything moves freely. I took some photos with my cell phone and ran a bore scope in to verify clearance.
I asked two knowledgeable buddies what they thought about it and one (former dirt track car builder) said should be good to go, and the other (old school drag racer) asked me how much clearance there was between the bushing and spline shaft. The latter got me second guessing myself.
I'm planning on mashing some putty in there to get a ballpark indication of clearance unless you knowledgeable folks can offer other guidance. Everything I've searched for talks about ID & OD dimensions but nothing really about gap between bushing and spline shaft. Thoughts?
