1 - 15 of 15 Posts
I want to start pining my own weather tight connectors. Is there a "master kit" that would be a good place to start to make my own connections instead of doing all butt connectors??
I used all modern GM connectors on my car.
i have used del city before
I think i used customelectricalconnnectors.com for the delphi stuff
Def get the larger guage terminals for the parts of the wiring that need double wires like the courtesy light grounds and tailight harness
Weather Pac pins are round and come in three sizes:
1. #20 - # 18 gauge
2. #16 - #14 gauge
3. #12 gauge
Weather Pac pins are rated for 20 amps regardless of the size.
There is a new type called Metri Pac. They are flat and also come in three sizes.
1. 150 series 1.5 mm terminals, 14 amps
2. 280 series 2.8 mm terminals, 30 amps
3. 630 series 6.3 mm terminals, 46 amps
The same crimper can be used for both types. Use the correct pin for the gauge of wire. Otherwise, you might not get a good crimp.
Do not buy Weather Proof connectors. They look very similar to Weather Pac. The pins do not insert into the plastic shell and the retaining clip will not snap in place.
Reactions: Just 1 More
1969 Camaro Restomod
I have a Klein Tools crimper, would that work or do I need a different one specific for the weather Pac? This is the Klein I have
Frank... chances are that even with using Delphi connectors you might need some different teeth inserts or other size crimpers. I have a similar HD ratcheting crimper with interchangeable teeth and a couple of smaller crimpers which are sometimes handier to use. I like the Delphi connectors, I used these for the dual eFans and those are the Delphi brand crimpers (blue handles) I used. They roll and crush the pins perfectly. The Pro's Kit Barrel Crimps also came in handy when doing my SpeedHut wiring with Deutsch connectors.
Tire Green Light Product Blue
Tool Line Electric blue Metal Wire stripper
Watch Toy Gesture Audio equipment Font
Product Rectangle Line Font Electronic component
Waytek Wire is also a great, low cost, supplier but there may be minimum buys.
Each system (Weather, Metri, etc.) have advantages and disadvantages. One of the more modern Delphi (now Aptiv) systems is the GT series. GT150 for 15A and under, GT280 for 25A and under. Sealed and unsealed plug bodies can be used but with different terminals. The best reference for all of the series is the Delphi Global connections catalog available here: Global Connection Systems Catalog | TTI, Inc.
The blue handle crimping tool shown in the earlier post is about the best overall tool for a very low price. Dedicated tooling is spendy. A single set of dies is $350 + $100 for the handle. To do 10-22ga two sets of dies are needed.
Discussion Starter · #13 ·
Del City web site, I ordered what I think would make for a "kit" , probably ordered some things I'll never use but I'll learn from it.. lol
They automatically applied a discount and free shipping at check out . . yaaaaay me.
Item Description Stock Qty Price
75000 22-20 Ga Purple Cable Seal Delphi 15324985 (1 MIN) In Stock 10 2.63
75002 20-18 Ga Green Cable Seal Delphi 15324982 (1 MIN) In Stock 10 2.42
75004 16-14 Ga Grey Cable Seal Delphi 15324980 (1 MIN) In Stock 10 2.41
75006 12 Ga Blue Cable Seal Delphi 12015193 or 15324981 (1 MIN) In Stock 10 2.42
75008 20-18 Ga Orange Cable Seal Delphi 12129930 (1 MIN) In Stock 10 10.10
75010 Weather-Pack 1-way Connector, Tower (Female) Housing 12015791 (1 MIN) In Stock 5 4.23
75012 Weather-Pack 1-way Connector, Shroud (Male) Housing 12010996 (1 MIN) In Stock 5 3.20
75014 Weather-Pack 2-way Connector, Tower (Female) Housing 12015792 (1 MIN) In Stock 5 4.59
75016 Weather-Pack 2-way Connector, Shroud (Male) Housing 12010973 (1 MIN) In Stock 5 3.45
75018 Weather-Pack 3-way Connector, Tower (Female) Housing 12015793 (1 MIN) Call 5 5.08
75020 Weather-Pack 3-way Connector, Shroud (Male) Housing 12010717 (1 MIN) In Stock 5 3.69
75027 Weather-Pack 24-22 Ga Male Terminal, Loose, 12089307 (1 MIN) In Stock 10 16.35
75029 Weather-Pack 24-22 Ga Female Terminal, Loose, 12020801 (1 MIN) In Stock 10 4.52
75030 Weather-Pack 20-18 Ga Male Terminal, Loose, 12089040 (1 MIN) In Stock 10 4.09
75032 Weather-Pack 20-18 Ga Female Terminal, Loose, 12089188 (1 MIN) In Stock 10 4.10
75034 Weather-Pack 16-14 Ga Male Terminal, Loose, 12124582 (1 MIN) In Stock 10 4.09
75036 Weather-Pack 16-14 Ga Female Terminal, Loose, Delphi 12124580 (1 MIN) In Stock 10 4.09
75038 Weather-Pack 12 Ga Male Terminal, Loose, 12124587 (1 MIN) In Stock 10 5.29
75040 Weather-Pack 12 Ga Female Terminal, Loose, 12124581 (1 MIN) In Stock 10 4.77
75044 Weather-Pack 4-way Square Connector, Tower (Female) Housing 12015798 (1 MIN) Call 5 5.70
75046 Weather-Pack 4-way Square Connector, Shroud (Male) Housing 12015024 (1 MIN) In Stock 5 5.00
When I did my conversion, some of the connectors I ended up using the Metri Pack ones for the fan, the amperage/wire ga. generally dictates the connector type. These tools helped me, blue one for Delphi and the other one for getting the factory terminals out of their sockets.
Water Landscape Metal Wood Fixed link
Wheel Train Automotive tire Vehicle Alloy wheel
1 - 15 of 15 Posts
