I am getting ready to re-assemble my car from the rotis, and need to decide between PST's poly-graphite bushings or Global West's delrin bushings.
I intend to keep my car as stock as possible (engine, exterior, interior, a-arms, etc) but also want a nice handling, driveable car. PST bushings appear close to OEM, but do they squeak and bind? Example...with coils not yet installed, delrin bushed a-arms move extremely easy allowing the suspension to 'work' better vs. poly-graphite/poly-urethane which bind and dont move freely with same example. SO, does this even really matter for my car? Is seeing those blatently non-OEM delrin bushings worth the benefits I get for my cruiser convert? And the price difference?
As for springs...I again want a good handling car and had intended to re-install the cosmetically rejuvinated stock coils and springs, but they are 40 years old and surely wont provide the originally weak lbs/sq. in. they once did. SO I have been considering the ~1 inch drop replacement springs (front & rear) from Global West. Not so concerned about being ~1 inch lower than stock since my stock gear is probably similiar by now, but not having a mono leaf in the rear on a 67...that will really be apparent. Repro mono leafs arent the same, so not even considering them. Is having a modern rear spring rate in a car that was obviously undersprung originally, worth having obviously non-stock rear leafs?
I want to cruise the car, but have gone to extremes in keeping as much original as possible. This is likely the highest optioned car I can afford and realize the increased value in maintaining original equipment...but I want a nice handling car I can use for the next ~30 years. Regardless of my decision, I will always keep the original springs, but for now...
Please enlighten and help me decide. I have read numerous threads and narrowed my choices, but am now stumped. Thanks in advance!
My polyurethane bushings sqeeked like crazy against my old powder coated subframe. Their lube, or any other I tried had no effect. Drove me nuts!
I went back to rubber and paint.
