I have a 92 Camaro RS with 135,000 miles. I was driving the other day and the thing just died for no reason. No symptoms of any kind. It isn't even storing a malfunction code. Anyone help me or point me in the right direction. Thanks. BTW it runs fine now.
I dont know if this is it or not, but My 91 firebird had a issue with the VATS sensor a while back , I had to have the ignition lock tumbler changed because it busted. and over the years it was tearing a wire on the vats sensor that would cause my car not to start at times, then I would wiggle my wheel around and it would restart, i hear that it can cause issues while the vehical is on also... this may or may not be the cause, but is usefull information either way, Good luck
Chris's 67 RS/SS,can be seen at http://www.67rs.com
check out another site once in a while! http://www.fbodyconnection.com
Start with the simple things check/change out fuel filter could of pick up some trash buy a good fuel system cleaner and pour it in the tank. Did car start right back up? Were you turning a corner when It died?
Hope this helps
Jeff
Hey Chris I lived in Annapolis in 90-92 while in the military sure did love cruising up to Glen Burnie use to have cruise ins out by the Airport some awesome cars from around there.
Jeff
Yeah I was going around a curve. It started after it sat for awhile. It hasn't done it since tho.
