I replaced the hoses that enter the heater core w/ a chrome version. I started the 69 camaro up and I have antifreeze leaking from the bottom of the heater core cover. It doesn't look like it is leaking from the new hose connection. It looks like it is running around the cover on the fire wall of the heater core. What can I do to fix this? Thanks for your help.
Sounds like u may have just bent the core outlets slightly lining them up or removing adding the hoses...doesnt take much to get a crack on the core where the tubes go in.
DDid u pull the old hoses off or cut them off? they need to be cut off to advoid issues
Pull the heater core from under the dash, get the leak fixed and put back.
When u get the leak fixed, make sure u have the tubes exactly so they will slide striaght thru the firewall with out tweaking
