Please understand as I ask this question, I'm not looking for the best possible (go and spend another $500) carb. I'm mainly wondering if this carb will work fine, or if I should move up to an 8-ish cfm. I have a 460 BBC, closed-chambered oval heads, about 10:1 compression, comp 280H cam, Performer PRM intake, headers, M-22, 3.73 gears.
I know that most tend to over-carb, but a 460 isn't exactly small (I know...I know...there are some monsters out there now). I'm running a Holley 750 DP now. Just wondering if I could get quite a bit more by running an 850......or if a 750 is more than enough. Thanks guys!!!!!
Oh yeah.....if you look at my "signature", this is not the Camaro.....it's a 4,000 SWB truck......and no I will not switch to a vac. because of the weight.....I already did that and it ran sooooo much better with the DP!!!
an 850 wouldnt make the bang for the buck I assume you are looking for. :D
AE2
Stick with what you've got...its perfect!
