i need help from that has desktop dyno. i need to see if someone could run it through the program and tell me the hp and tourqe ratings. i have a 350 thats .40 over, 9.5 to 1 forged pistons, dart iron eagle 2.02 heads, stock port. 3 angle valve job. eagle esp rods,rotating assbly is balanced, lunati cam (jegs part num 638-00012, braket master) 300/300 adv duration, .515/.515 gross lift, .264 @ .50 and 108 lobe seperation. 1.5 roller rocker arms, windage tray, torker II intake, edelbrock 750cfm carb, headers (small block s 10),dual flowmaster 2 1/2, th-350 with 2600 stall and shift kit and 3.42 gears. all is a 85 s 10
OK, here you go. That is a pretty big cam!
It made 448 hp and 410 lbs. The second set of graphs (the higher ones) are a roller cam with your same specs. I thought you might be interested. I only have exact flow specs on the 200 CC intake runner, 64 CC chamber Iron Eagle heads so that was what I used.
http://www.dixonottawa.com/pics/dyno.jpg
[This message has been edited by Chris Davis (edited 03-02-2001).]
insane,
I have a friend that has about the same combo, but it's a 383 in an S10, and he runs 12.50's on it with traction problems.........ought to run!
And that should be 300 adv./[email protected],not .264 and .515 lift,correct?
383 Speed-O-Motive stroker kit with Speed Demon 750, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and 3000 stall.Powertrax NoSlip Locker
[This message has been edited by Tracy Focht (edited 03-02-2001).]
