721 - 740 of 761 Posts
Update : Just got my DIY lowering blocks done and installed. Cutting a 0.9" solid steel block with a basic angle grinder was hilarious...
Total rear drop : Hotchkis 1.5" drop multileafs + 0.9" solid steel lowering block. No spring pads.
Here's a pic with the lowering blocks installed.
No rubbing front or rear, but I'm afraid it can rub the rear lip when going over a bump or curb at an angle. So I will roll the fender lip a bit, not all the way around but from 10 o'clock and 2 o'clock down. At about 2 o'clock (drivers side, towards the rear) is the worst point on the lip imho.
1969 Camaro Restomod
Here's my current setup. The front tires are 215/70-R15's on 6" Wheel Vintique Chrome Rallys. The Rears are 255/60-R15's on 8" Chrome Rallys. I forget the backspacing, but will repost or edit next time I take the wheels off. The front has 2" drop from Hotchkis springs. The rear? LOL... tired mono leafs, but I'm gonna eventually switch to multi-leafs. Maybe it'll change the stance, but we're about to do the front end all over, add Helix upper and lower control arms, ProForged BJ's (tall uppers/reg lowers) and tie rod ends, Wilwood Calipers & M/C, CCP slotted rotors, and a JGC steering box. Soon I'll add new front and rear sway bars, maybe coil-overs down the road. The rear? I'm leaving t until maybe I find a Nova 8.5" and then I'll probably go with a Detroit Spring multi-leaf pack. I like a slight rake.
277298
Wheels wise... I'm torn between the 17" or 18" school of thought and sticking with 15" wheels. I have always liked the Cragars on these cars more than any other aftermarket wheel. Someday I'll figure out which direction.
The car had a 2-1/2" exhaust and it was not hung well, rusty, and was hitting every time I went over a peanut. I replaced it with a full 3" PYPES SS system and only had to "massage" about 3" just past the DS shock... but no more exhaust pipes hitting. On a very steep driveway entry (mine), I get a tiny rub from only one direction, but never get the rub driving around ever.
I'm running a bone stock suspension set up. Big block springs up front and multi leaf springs in the rear. My car came out of restoration wearing 15x8 4.5" backspacing Rally's with 215/65/15's but I wanted a different look. I was torn between staying with 15" wheels or upgrading to 17's or larger. Until I saw a local Craigslist ad from a guy selling a set of like new 15" Torque Thrusts with tires from a 69 Camaro. He was replacing them with 18" wheels.
Since the guy was only about 4-5 miles away, I ran over to look at the wheels. He had already bolted on the new 18" wheels and I frankly just did NOT like the look. I grabbed the Torque Thrusts with tires for $850.00 and sold my 15" Rally's on Craigslist for $500.00.
My set up: AR polished Torque Thrusts. Front 15x7 with 4" backspacing with 225/60/15's. Rear 15x8.5 with 4.5" backspacing and 255/60/15's. I love the look.
Although most of the photo links have been broken in this thread I guess I'll attempt to revive it. I was one of the photobucket "casualties" on a number of other forums that didn't allow direct links from computers/twblets/phones like this one. I've resorted to using postimage.org . It's free and easy to use.
I'm not happy with the rears (not wide enough) but this is what I have for now. American Racing Torq-Thrust 17x8 (I think) all around with 225's in front and 255's rear. I've acquired the car as is without all the specs.
Widest you can go is 275 without minitubbing the car. Is it worth spending money on new tires etc to gain three quarters of an inch?
Don
So I've read all 49 pages of this post and appreciate all the helpful information everyone has shared. I have a stock 1967 convertible and would like to put 18s on it. From all the posts that included 18s, it seems that folks are safely using the following:
Front - 18 x 8 with 4.5 inches of backspacing. 245/40/18 tires. Is this enough backspacing?
Rear - 18 x 9 with 5.25 inches of backspacing. 275/40/18 tires. This rear wheel/tire setup appeared several times.
I also see smaller:
Front - 18 x 7 with 4.25 inches of backspacing. 225/45/18 tires.
Rear - 18 x 8 with 4.5 inches of backspacing. 245/45/18 tires. is this backspacing correct? Should it also be 5.25 inches?
I would appreciate any and all thoughts or recommendations. I would like to use the largest tires without rubbing. Thanks!
I personally don't like to drift to far from the original integrity of the great design of the first gen cars. I like a decent sidewall and not too large a tire/wheel combo to distract from the car and too large can cause issues that I am sure you read about and in some cases expensive mods to accommodate wheels that were not designed for the car. The ride can be compromised as well with "rubber band" tires. On my 35th Camaro I went with 17 x 8, "0" Foose Knuckles as I wanted something different than what everyone else has on all 4 with 255x45 and 235x35. The difference in "larger" is in many cases less than an inch. No issues and the car rides on stock suspension that is lowered 2". The only drawback is the ride is not as smooth as my one of my other 69's that is a 55k all original with 215-70-14!!!! Just an old guy talkin. . . .
As you've had or have 35 Camaros, do you have any experience with the specifications I mentioned in my post?
This thread needs to stay alive, so I'll add my current setup:
Car Tire Land vehicle Wheel Vehicle
Wheel Tire Vehicle Car Land vehicle
Front wheels are 8" X 17" with 4.750" backspace, tires are Firestone Firehawk Indy 500's 245/45-17.
Rear wheels are 9.5" X 17" with 5.500" backspace, tires are Firestone Firehawk Indy 500's 275/40-17.
Edit Spring 2022: Will add new new front shot with RS/Endura/Painted Spoiler as soon as I get her back on the road.
Any experience with the specs I listed?
i would not a 18x8 up front with a 4.5" bs. I have run 3 different sets 18x8's up front on my 69. Sizes were...4.75" bs.....5"bs ....5.125" bs. The last set up fit best with no rubbing. My car sits low so makes for less room. For tires I have run 235/40/18 and 245/40/18. The 235's fit best IMHO.
If anyone has a (or 225) 235/45/17, 255/45/17 (8"width) setup could you repost pictures and details? I am thinking of that combination and saw there were some on this thread but the photos are not showing up anymore?
