Hi Guys ...
I'm not sure what tire size to run up front ...
I need to get some tires on my 15x6 torq thrust II wheels and would like to know what you're running ...
Front,
Stock Ride height with new 90/10 shock and new stock length springs ...
Rear,
Stock Ride height with new 70/30 shocks, CalTrac split monos, and 15x8 wheels with 275/60/15 Mickey Thompson ET Streets ...
Discussion Starter · #2 ·
Maybe 205/60/15 or 215/60/15 for the fronts
Discussion Starter · #4 ·
Nice Doug ... What's the rears? ... and is that stock suspension height?
Discussion Starter · #5 ·
I need to freshen up on the geometry or ride height of our cars from front to back ...
With me running 275/60/15's in the rear (60 mm sidewall height) and if I then ran the 205/65/15's up front (65 mm sidewall height) ...
Would this tend to make the car appear to be sitting a little higher in the front?
I'd like to have a slight rake with the rear sitting a tad higher than the front ...
205 = mm wide (25.4mm = 1") so approx. 8" side wall to side wall.
65 is the aspec (or side wall from rim to tread) so times by 2 and add 15" for wheel.
205/65/15 = 8 wide x 25.5 tall (approx) and a 60 would be about 25" tall.
Thanks for the compliment.
285/60/15 SH McCreary's (yes they rub on hard turns and off camber bumps)
Original rear mono leafs (now Z28 style 4 leafs due to mono's getting bent)
Z28 coils front (Moog replacements)
The front looks slightly high due to launch (pic) and I hope to hang a wheel next trip to track (new combo,maiden voyage 24 March)
Discussion Starter · #8 ·
Ok ... Cool Doug ...
So the 205/65 >>> 25.5" tall ... teh 205/60 >>> 25" tall ... and I beleive the 275/60 is 28" tall ...
This should give a slight rake ... and look nice ...
