I am hooking up my new guages, oil, temp and voltage, and the instructions call for a power source that turns on with the key. On my fuse box there are a couple of open slots for what I thougth were accessories. Can I plug into these? Where is good place for gauge power? thanks . I hate wiring :mad:
Thanks Scott. I need to get a battery soon, so I'll give that a try when I hook it up. It seemed too easy so I thought I would ask.
On my 68, I found an extra wire taped up in the harness with an insulated connector on it. I think it may have been for optional A/C. In any event, it might work for you. But I can't recall if that is B+ or ACC power. Probably the fuse block is the next best thing.
I just installed a new Hurst V-matic shifter in my 68. I used the open, bottom, center pin for power to the shift indicator light. It is switched to the key.
