Hi Everyone, this is my first post on Camaros.net and hope to get some great advice,
I’m restoring my wife’s 69 RS Convertible which she got from her father, the original owner. It’s got a stock 327 with an MSD distributor. It ran pretty good until recently when the ignition resistance wire lost power. Rather than replacing it, I heard it’s better to bypass it back to the IGN terminal on the fuse box to get a full 12v. I did that and everything was fine for a few hours, but then the fuse for it blew while I was doing compression checks and cranking the engine quite a bit. It appears to be the Turn Signal fuse. Not sure if the blown fuse was related to me doing a lot of cranking, or if powering the ignition is just too much for this fuse. Could really use some sage advice about now. Or maybe recommend a better source for ignition-on power for me to tap to reliably power this MSD distributor?
Thanks!
Neil
Thanks!
Neil
