1 - 8 of 8 Posts
Yeah, should be common... From what I see everyone is swapping from the original box to an Iroc box or some aftermarket version. I'm using a factory box and have a -6 with my new Holley front runner set up. I'm wanting to just use a -6 line with an adapter fittings on the original power steering box.
1969 camaro power steering box....
I've done some digging and wanted make sure this is what I needed before I ordered it...
https://www.summitracing.com/parts/rus-640380
https://www.summitracing.com/parts/rus-648050
Also, is the power steering cooler normally ran on the pressure side or the return side?
Below is a pic of my power steering box, I'm assuming it's original. No telling on a 49 year old car. I threw some kind of plug on it to help seal it while it set up for a while...
Untitled by zboss86, on Flickr
The casting numbers would help identify if it is original.
have 67 camaro, stock power steering pump w/ grand cherokee gear box. Can i use these adapters? If yes, then where can I find pwr steering lines that work with this solution? Thank you in advance.
Dang Shad, you have your Holley stuff in before I do? LOL Have been too busy with work and other stuff to do it. Getting ready for some other changes also..... Nothing drastic, just making what I have better ;-) Hope to be able to see you guys at CTC.
And here is my answer....o ring inserts....no more leaky leaky...speedway Part # 91032921
1 - 8 of 8 Posts
