Hi guys, this 67 I am playing with is currently a manual steer car and I bought a p/s steering box for it. I was wondering how you bolt up the 4 bolt p/s box to a 3 hole m/s frame. Do any of the existing holes match up to the new box? do you have to drill any or what? Also I know the pitman arms are different from m/s to p/s but are the center links also different or will my existing one work with a p/s pitman arm?
Thanks guys! Danny
I didn't build it, I didn't break it so lighten up, I'm just trying to fix it
There was a thicker center link for big block and air cond camaros that was used in the later years.
A small block can do fine with the standard center link.
The four bolt box only uses three holes on a Camaro application. The same three holes as a manual box.
Ihave more info on my page below.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350 Can-Am Vintage Racer
Discussion Starter · #3 ·
Thanks David, I appreciate the info. You have some great camaro pages! Danny
Hey Midnight.. your going to love the PS when you get it. I just did a conversion on my 67 and it works great. you will need a new rag joint for PS as well. the shaft on the manual box is smaller than on the PS. you will need a new pittman arm for PS as well.
67 Camaro
84 Z28
89 Camaro
http://members.ebay.com/aboutme/[email protected]
