It seems like the simplest things slow you down...
I'm trying to attach my low pressure hose to the male outlet from the power steering pump on my 67. I'm using the original power steering box with a Tuff Stuff Saginaw pump and high quality rubber hoses. I cannot get the low pressure hose (3/8") over the rib of the male outlet. The hose is rubber, but it has braided steel embedded in the rubber. The braided steel will not let the hose go over the rib more than 1/8" so T can put on the hose clamp.
Any ideas...cut the rib off??? See pics below. Thanks!!!
Nevermind. I got it on, finally. I had to twist it on using a lot of force. It is amazing how little a braided hose gives. Thx.
