Swapped my 86 350 block for a 76 block 4 bolt main, The harmonic balancer is bigger on the 4 bolt thus not letting the pump bracket fit. Going in my 68 RS. Is there an aftermarket that would work ? Thanks
Bill
Tom -
so exchanging the balancer will not effect the way the eng. runs ? I was afraid of vibration.
A larger balancer will absorb more vibration. You may want to check with a more qualified engine person, but it has been done many times. You might consider a new aftermarket balancer, of the smaller diameter. If the engine was a 400 (externally balanced) you could not swap the balancers.
