1 - 1 of 1 Posts
Hi All
Went looking for pictures for the Power Window Relay, and Wiring Diagram to figure out the Mess the Previous owner made with my 69.
I do have the Fisher Body manual and figured out the Pink and Orange wires that were Cut go to.
Another Member was looking for help and I sent some Pic’s for the Relay install and Wiring, So I figured I would Share them for anyone else looking for them.
The Last “Pink” wire picture shown is on the Wrong Terminal, it should pick up the IGN. Terminal in the Fuse Block.
As most Posts tell you to Take more Pictures than you need, you might catch a view of a Screw Head or Direction that Circuit Breaker is mounted in my case, all very helpful.
I spend as much time searching the Net for Pictures as It takes to install the part sometimes !
Timmy
1 - 1 of 1 Posts
