Look at the case, they will be either alum. or steel. More than likely, alum., Ive seen more alum. than steel.
67 Camaro SS Conv.
70 Challenger R/T Conv.
Hey James,
The glide has near square pan,the TH350 has near square pan with one corner cut off.The shifter on the glide will have 5 gear positions,the TH350 will have 6.The glide will have a 3 bolt servo cover pass side triangle shape,the 350 will have round servo cover w/ snap ring retainer also pass side.
Larry
POWERGLIDE IS FORGED INTO THE CASE i THINK IT IS ON THE "PASSENGER" SIDE ALSO A TH350 USES A CABLE KICK DOWN AND A PG USES A LINKAGE THAT IS MOUNTED WITH THE SHIFT LINKAGE A TH350 IS A DIRECT BOLT IN FOR PG AND IN MILD FORM IS A GREAT CHANGE FOR PG BUT IF YOU GOT LOTS OF GEAR STRIP ONLY CAR THE PG IS THE HOT SET UP IF ITS BUILT RIGHT
