As noted, you need to know whether the drivetrain (302, M20 & 12 Bolt Rear) are simply correct replacement parts or TRUE ORIGINAL EQUIPMENT. You/we need pics of the motor front stamp pad, rear casting number, head casting #'s, carb stamp #, intake & exhaust manifold casting #'s, transmission casting & stamp #'s, rear end casting #, etc. What is the rear end gear ratio? Is there any original documentation and anything on the rebuild of the motor to confirm whether the internals are original or replacement parts? Finally, what is your intended purpose for the car, ie: cruise or just for show. This one is up there in value that would make me a little uncomfortable driving it on the freeway. Beautiful car! Good luck in your search. At this price range, there are fewer buyers, so take the time you need to make sure you are getting EXACTLY what you are paying for----- mistakes will be costly! Charlie 69 RS
