On the 3rd gen F-bodies with the dual electric fans, which one is the primary fan? I am wanting to splice into the primary fan wire and hook it up to the secondary fan so that they will both come on and shut off at the same time. I have an 87 GTA(sorry but also have 69 RS) with a 350 and just want to cool it down a little quicker. Has any body else done this? If so, any horror stories? Please let me know. Thanks
there are some aditives tha help water disipate heat more eficiently ,silo engine cool is the one i have purchased from napa,works well to lower temps.I have seen 20 degres lower temps.
I spliced the my fan straight to a toggle switch with a light to my fans but still had it hooked up to my regular set up so I could control when my fan came on manuelly while still worked with the regular setup. I mounted the switch right below my lighter. I can keep it from breaking 160 if i wanted too. But keep an I on your temp guage just in case you botched it up.
