I am using an old distibutor shaft (without the gear) to prime a new motor. I am spinning the drill clockwise at I am guessing 1000 RPM.
There is only a small bit of oil at on rocker. What should I expect to see. Seems like I did this before and seen much more oil at the heads.
What could I be doing wrong?
Thanks Again
You need to stay at it longer and rotate the crankshaft 90 degrees by hand several times for a full burp.Patience will prevail.
That sounds great just to see the oil at the rockers, sometimes you have to bump the motor over a little. But thats all you need or it could just be thick oil.
