Slight problem with turn signals, I think it might be a flasher problem but wanted to here fromt the experts. First off I have no turn signals at all either side and now when I hit the brake pedal the front parking lights come on with the rear brake lights. Any ideas where to start looking? Any help would be greatly appreciated!!!!!!!!!!!!!!
Do your hazard flashers work as they should?
The usual reason for the front signals coming on with the brake lights is the hazard switch being turned on. If your hazard flasher is bad and the hazard switch is turned on, this could be the whole problem. Be sure the hazards are turned off and see what happens.
Steptoe said:
Check your earths
aka your grounds.
check all of your grounds.
Thank you all for your responses. Red67 you were right on, problem with the flasher button on column. I was able to pull out clean up contact areas reinstall and WA LA I have turn signals again.
Thanks much..........
