I have a small problem with my fuel-level indicator. I just lowered the car a bit (front and back), so that the space in the wheel-openings in front and in the back are the same height.
The problem I have now, is that when I filled the fuel tank completely full, it only indicated half-full.
Could this be because of the car-stance changed?
What can I do to get a good fuel-level indication??
Sounds like either your floater is not working properly anymore or there is a ground issue. I would suspect a grounding issue with the sending unit in the tank, check the wire and redo the ground. There is no way lowering a few inches front or back is going to cause the floater to not float to the top.
