Where is the right jack point to raise one front side with a floor jack?
John
I usually go under the control arm with a block of wood wrapped in a towel between the jack and the car. If you're careful you can use the center of the front crossmember, but they dent easily.
You can also go right behind the body mounts.
If you're only raising one side I would either go under the lower control arm or under the subframe just behind the body mount as has been posted already.
