Is the proportioning valve the same On a 1969 camaro from disc brake to drum brakes.
thanks
if you are talking about the flat rectangle valve all the lines under the master cylinder go into then out to the wheels they should be the same . if you mean the round valve drum doesn't use it . the brass valve on the side of the sub frame is front for disc
Thanks Mark, once again your advice is very appreciated.
Today i picked up the drum brake hubs, brake line brackets and housing ends.
tomorrow, i am meeting a local vette parts dealer, he is selling me a complete Corvette brake system ( great for mock-up and cores) for less then $150.00.
Although i will problably just use the Rh bracket
Yup -- stock setup had a distribution block under the master/cyl that was the same for all systems.
Stock disc/dum setups had a round hold-off valve that delays front brake operation until the rears grab a bit (apparently needed to make sure light brake application would stop the rear wheels from spinning when stopped at a snowy intersection).
Some stock applications also have a proportioning valve mounted on the driver's side of the subframe (under the driver's door area).
