I have a 69 Camaro that has been causing me fits. I put in a new master cylinder. A Dorman 13-1423, supposedly for 67-69's with front disc brakes. It is what they call a Z28 type. It acts like there is air in the lines. I bleed all 4 brakes and the pedal feels great, until you start the car and the pedal drops almost to the floor. This car is a factory LM1 car. Stock front disc brakes and a 12 bolt rear end. It does not appear to have a proportioning valve ! It only has a distribution block. If this is all that is required, I assume that this master cylinder will not work ? If this is the case should I just install a combination proportioning valve/distribution block (PV 2) ?
The first image is my original master cylinder.
The 2nd image is of a pv 2 proportioning valve.
The 3rd image is my new master cylinder installed
