1 - 2 of 2 Posts
I just purchased QA1 coilovers for a small block first gen from ebay. The outside of the box says GMP-14 and the decal on the spring box says 11-250/350. The decal on the shock box says GMP-1. Is this correct? What does 250/350 mean? Is that the spring rate, because that seems real soft. Can anyone shed light on weather these springs feel too soft or not? Thanks
They are a variable rate spring, I believe. The 250/350 are the two spring rates. A stock spring is about 327 so your are basically running a stock rate spring.
1 - 2 of 2 Posts
