So I don't work in the automotive industry but have built more than a few engines in the last 40+ years. The quench on these engines has been from 0.057" to 0.040" to unknown with my current dished piston blown engine. In my years on this forum I have seen so many individuals get hung up on getting the perfect quench. based on my experience, my opinion has been that quench is important just like many other items associated with building an engine like piston to cylinder clearance, ring end gap, bearing clearance, etc. but there are other factors that influence a tendency for an engine to ping or detonate. It's all about the total package.
The engine that had 0.057" quench was a 10.9:1 compression smallblock that cranked 215-230PSI on a cold compression check. I ran that car for years on 91 octane pump gas and there was never an indication of detonation. I believe what helped it was the 4.10 rear gear, 5K ish converter and 3,400 pound race weight. That same engine in a 4,000 pound car with a manual transmission and 3.07 rear gear would probably have issues with detonation on the same 91 octane pump gas.
So now lets move on to a dished piston engine on boost. My current setup has dished pistons. The pistons are zero decked and the tiny bit of quench that it does have is at 0.040". Most engines have the entire flat area of the head and piston for the quench area. A dished piston like the ones in my engine has a ring around the top that is only about 1/8" wide. The quench area is greatly reduced but this engine runs at 27 pounds of boost. So again, it begs the questions. How important is quench?
It would be great for people to contribute actual data to this thread not just opinion. Again, it would be great for people to contribute actual data to this thread not just opinion.
