I'm doing a "homemade" disc brake swap. C5 calipers with C4 rotors in the front, 93-97 Z/28 discs in the back.
My questions, for now, are on the rears.
I found the rears at a wrecking yard. I got 2 right hand brackets, and two complete right hand calipers, including the e-brake cables. I'm rebuilding the calipers.
1. I've heard the z/28 rears also referred to as "C4" brakes. Are they the same thing? My main question concerns the rotors. If I purchase C4 rotors from e-bay, will I get a rotor that will work with this set-up, or should I get a rotor specifically for the 93-97 Z/28?
2. My calipers came with a hockey puck sized cast iron weight on them. It hangs off of the e-brake bracketry. I think I read in the archives that it's intended to reduce pad squeal. Is it necessary on this swap? If not, I'll just cut off the long stud that attaches the weight.
3. I know I can get cables made by control cable for the e-brake, but I think I can make the cables that came with my calipers work. They are about 3 feet long, so I'll have to cut the housings down to fit and then install new ends in the forward end of the cables. Does anyone know of a way to fasten a new cable end onto a cable that will hold the tension required without slipping off?
Thanks for your replies!
