I'm in the process of pressing the bushings but had a question on the shaft. Is there a certain way these are supposed to be installed? I noticed a slight discrepancy in size as you can see from the pics and I'm just trying to make sure I don't botch the install. I'm trying to return this press tool and it's quite the drive so I don't want to head back if I mess this up.
68 RS L30 AA 749 Fred Gibb Chevrolet
Here's a shot I have on file. Not mine, it's someone here. Was compelled to save a copy as the quality and detail is top notch, although probably not factory correct as I believe the "dog bones" and washers were all painted black (after assembly).
Looks like the big end is to the front? I can take a look at mine tomorrow if needed...
Motorcycle Bicycle handlebar Automotive lighting Automotive tire Motor vehicle
Discussion Starter · #5 ·
thanks for the photo! After more research, it doesn't look like it matters. the area where the bolts go through will sit flush with the sub-frame regardless from what i gathered.
