Hi all, I'm going to start putting the final pieces together on my brand spanking new 383. I'll be yanking out the 327 this weekend. I was wondering if anyone can recommend what I should/should not reuse from my old motor. I am specifically talking about:
H2O pump- 327 is a short cast Iron pump
Pulleys
Alternator Bracket
Stock points distributor
Fuel Pump
Should I stick with the short water pump configuration or go with a new long-style aluminum water pump with new pulleys and brackets?
I'm planning on upgrading most of these parts in the future. Should I upgrade anything now to avoid any headaches getting this thing running and broken in? Also,should I upgrade the fuel pump? anyone have any recommendations there? its mostly street driving. specs are below.
thanks,
[ 03-19-2003, 09:01 AM: Message edited by: GregD ]
When I converted my 68 from 6 cyl to 350 I used all the accessories from a 69 (long water pump) because it was too hard to find all the right stuff. I'd recommend staying with what you have. If you decide otherwise and want to sell everything you have, let me know. I'd prefer to put mine back to stock 68.
greg,
i believe everything can be swapped over. i went from a 327 to a 381 and reused my 327 stuff to save money. i had a semi-new long water pump on the 327 though. with a new motor and plans for a new water pump, i would opt to put a new water pump on now, but i know things add up fast.
i also switched from the old school points to a summit HEI distributor, has a 48K volt coil. i love it, very good upgrade in my opinion, i saw better performance and gas mileage. it is a tight fit to the firewall. theres a lot of ignition options out there to choose from.
let us know how your 383 runs, the combo looks stout! you'll definitely be wanting a posi in there, especially with that 3.06 first gear!!
good luck
kip
I think I'm going to stick with the short water pump and pulleys for now to try save a little bit of money. I'm thinking of going with an MSD6-AL and using the crane points-to-digital conversion kit on my current distributor. A posi rear-end is on the list too. Not sure if I should stick with the Stock 8.2 10 bolt or spend the extra money and hunt down an 8.5.
Thanks for the input.
hey there,
sounds like a nice ride you've got there!
I just replaced the '72 engine in my (true) 68SS350 camaro. I can tell you for a fact, those pulleys and brackets are worth their weight in gold! If you're really goin' for it, the SSs have special P/S brackets, and an (optional?) chrome/"bright" oil filler cap on the tube. I personally think that the short water pump engines have a bit of a cache to them. 69 an up cars all look the same. If you can have the killer combo (like you do) and still look old-school, that's when you've got it. :cool:
oh! just thought i'd add; Petronix has this new point replacement kit that totally fits inside the old distributor and has a built in rev. limiter!! Hmmmm....
