As a favor I'm care-taking a 69 SS stuffed in a shed 45 minutes north of me. I head up once a week to check on his property and I either run it or drive it around town running my errands to keep her loose while he is overseas.
I've been noticing a little seepage at the core and tank sides. I'm fearful it will blow out on one of the starts or drives this winter.
I looked at the Harrison reproduction listings but can't find one fitting the GM part number 3020093 with the "ZH" tag code at HBC. I know two cores is weird on an SS but he wants to keep it stock. Anybody know if Harrison made by Heartbeat City make one for the 3020093 with the "ZH" tag code?
While I was scrolling over the many Harrison options on the website I was a bit put off by the statement that "the radiator will start to rust in 24 hours after shipment due to the manufacturing process." Telling you to send it out to be glass bead blasted before painting. WTF can't they coat the steel to inhibit rusting? It is already over 500 bucks before you add a blaster to the mix.
I had this same radiator type rebuilt a while back on my Z-11 and I'm happy with its performance and look. It cost a lot less then the Harrison repro. But I don't know the condition of his or if it is recorable? No one seems to make the two core tracks either to support a recore and his is looking a bit less well for the ware.
Any advice would be appreciated
