1 - 20 of 22 Posts
On my 69 I am about to get a new a radiator and the choices are 20 inch and 23 inch. I am ordering it from out sponsor Radiator.com. But I have a 69 base coupe with a 350 in it. What is the correct core size, 20 or 23?
Tim
If you're after originality, get the 20", if not I'll recomend the 23". Just in case you need the peace of mind in the future cause of engine mods or A/C install. I have a 23" incher on my small block with pre-formed radiator hoses without problem, 'til now. Just now that the A/C was installed, arrises an issue in which the upper rad hose gets too close to the Delco A/C compressor clutch. I need a new hose with a tighter curve immediately after the water outlet to clear the comp. clutch ***'y. Thats the fun of our hobbie.
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
The core support has the holes for both the 21 and the 23. The 23 will bolt right in.
joe
69 Rat-Infested Resti-Clone
WCA Member
[email protected]
69 Pics http://hobbystage.net/camaro/joeg/
[This message has been edited by Joe G (edited 05-18-2002).]
The SBC Fan Shroud was available in both sizes. My California (LOS) car with factory A/C and H.D. Cooling had the larger radiator and shroud with the fan centerline offset to the side.
I believe the re-popers sell both sizes still.
My new GM shroud was ordered prior to my discovery of the "Team Camaro Force"
, so I got the small block one. I don't have to tell you I had to make some minor mods to it.
The small block shrouds came in both 20" and 23" sizes. Most of the the A/C cars (out west anyway) with H.D. Cooling had the larger 23" rad. and the shroud had an offset to one side for the added length which caused the fan opening to be offcentered in the shoud. I have had this set-up on two cars with factory A/C now.
I'm pretty sure that the shrouds are still available from the suppliers.
I have one of each type still hanging in the shop and this thread sent me out there to check them again. These are not BB type, they both use the same mount type and are for SB.
I just ordered the 22 X 19 Griffin yesterday (It was 189). I'm sure I'll have to do some fabrication, but I'll let you all know how it goes. Does anyone know what hoses I should get? Just order them for a 68 with a S.B.?
68 Coupe, 350 4-speed
Jim's Camaro Corner
[This message has been edited by Spames (edited 05-20-2002).]
1 - 20 of 22 Posts
