1 - 14 of 14 Posts
My '69 is a factory air car, but i do not have the weatherstrip that mounts on the top of the rad. support. I inquired about it thru a parts vendor and asked about the plastic clips that are supposed to fit into factory holes on the support. The vendor says the weatherstrip does not come with clips.
To further complicate the matter, my car does not have the holes on the rad. support for the weatherstrip to attach to, although i see the dimples where the holes should be punched.
I am confused, did early cars not get this weatherstrip? (mine was born 11-1-68)
thanks,
mike
My '69 Conv. Website
or
FotoTime Pictures
[This message has been edited by mr69 (edited 05-10-2002).]
Mike, my 10/68 built 69 had A/C and definitly had the seal. Someone may have replaced the the radiator support at one time in your cars life and never transfered the seal over...do you have the side seal plates?
As far as the clips are concerned later model Camaros, like 2nd Gens used a similar clip (maybe identical) to hold the cowl to hood seal in place...just a thought. Good luck.
Discussion Starter · #3 ·
Panther,
I'm not sure what the side seal plates are, or what the clips should look like.
Could you take some pictures of yours and maybe email to me??
I really want to put it back the way it should be.
thanks,
mike
or
FotoTime Pictures
I second that... the original clips on my car are steel.
Steve - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> My Camaros (updated 3/7/02)
Discussion Starter · #8 ·
Steel? Seems like i someone once told me they were plastic, but nonetheless, the part vendor says there are no clips with their seal. (softseal)
I didn't even see the part in the Ricks catalog.
Has anyone purchased this piece from a vendor? If so, who??
or
FotoTime Pictures
I'm betting you could make new ones out of piano wire, available at any hobby store. Make an elongated diamond with two "ears" at the top, similar to the originals. You would choose a guage that would "squeeze" into the holes, and spring back, to hold the seal secure on top of the core support.
Should look like this:
V
The correct clips (or at least they looked like the original ones on my car)are available from any auto parts store that has a Dorman Supply or can order from the Dorman Catalog. I have also seen these type clips at some shops under the 'Help' brand products. The clips are metal and have a slightly greenish color to them when new.
What is the purpose of the side shields? I picked up a set at Carlisle but don't have AC. Would they help direct more air through the radiator?
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
Rick is corect, the seals are to seal between the fender, its extension , and the radiator support to prevent recirculation of hot air. More common on A/C equipped cars.
1 - 14 of 14 Posts
