OK, I need to vent.
Weather in Michigan is finally above 0 degF, so I got around to pulling the heads off my Camaro ('69 307). I knew the original owner had "hardened valve seats installed" at some time back and that the heads that were on there were no longer the originals, but when I had first checked (back in the days before the internet) I couldn't ID what they were. Well apparently, I had some rare heads on there -- 471513. Limited production 79-81 267 V8 heads. Cute little 1.72" intake and 1.38" exhaust valves. Haven't CC'd the chambers to sort out how bad my compression ratio was. I'm thinking this is why the car completely fell on it's face at about 4000 RPM or so even with the 4bbl and "performer" cam.
Cyl's are in "OK" (not too bad, not too good) shape so I'm still debating if I want to slap on some 305 HO heads and slap it back together or spend a bit more $ getting the short block freshened up. Plan is to eventually do a 383, but I'd need to swap the trans (3.42 ST10) and rear (8.2) to handle the torque and $ isn't that free-flowing right now. I'm also a bit curious to see how the 307 runs with decent heads since I alread spent the $ on the carb, intake, and cam (carb and intake will go on the 383 eventually and the cam was la summit special for like $70). The idea is to put a little bit of fun in the 307 and upgrade the trans/rear over the next couple of years in prep for the "real" motor.
Anyone want a set of ultra-rare no performance heads? At least I know the 416's should give me a good bump...
