1 - 2 of 2 Posts
Banned
RE: Late Ignition Timing
Hi.....I have one simple question regarding late ignition timing.....What are the engine running symptoms of late ignition timing on a small block chevy motor?.....In other words, how will the engine respond if the ignition timing were late?
Re: Late Ignition Timing
Popping through carb, temps will get hot very quickly water and especially exhaust manifolds/headers... also lots of stumbling when you try to rev.
Don't you have a timing light or at least tabs with a balancer that has a line in it? Put a light on it and you will find out very quickly what is going on.
1 - 2 of 2 Posts
