How do u guys think this will look/ fit on my 68
235/60-15 front and 225/70-15 rear with 4.5 back space
I got a line up on a set real cheap good rubber on weld draglites.
Thanks in advance
Thats the sizes they are..i could put them up front idunno
Wouldn't look bad from the side IMO. The 225/70's for the rear will still have a larger diameter than the 235/60's on the front, by almost an inch and a half. That's not a bad rake. Sidewall height will also be larger on the rears. The rears will be less than a half inch in width than the fronts, which may not even be noticeable. If that's what you have to work with, I'd see how they looked installed. That said, the 235/60's might rub depending on your suspension setup and wheel backspace.
Ok tx that sounds good thats the kind of answer i was looking for tx Chad. I do have a pair of 215/60-15 tires i could use in the front if need be. Would the 15x8 fit those tires ok? The backspace on everything is 4.5.
While 215's should fit the 8" rim, but they may look stretched. I'm running 225's up front and 245's in rear on 7" rims.
