Got a 69. I took this pump off to paint it. Do I have to bleed the lines before reinstalling the low pressure line or just connect the lines and keep filling it until its at its correct level?
I removed mine to paint too. Just hooked back up and filled to the top, then ran the engine and turned the wheel slowly, lock to lock, 6 times for the fluid to work back into the system. Worked fine after that. Remember its not under any type of high pressure at all either. :thumbsup:
