1 - 2 of 2 Posts
Hey all. I realize this is really hard to diagnose, but I wonder if anyone could try.
I think this may be a ground issue, but I'm not sure. My '69 has crazy weird turn signal issues. A lot of times, if I turn on a turn signal, I get all the blinkers going, like I turned on the hazards. Other times everything works perfectly normally. I don't really know where to look to see what the problem is. Any suggestions?
Sounds like a problem with the turn signal switch in the column. The hazard flashers are controlled with the same switch. The switch has a short harness that runs down through the column and plugs into a connector at the bottom of the column. More than likely the switch is bad or you have a couple of wires shorting in the column. Worth checking out.
'69 RS Camaro
355 5-speed 4.11
1 - 2 of 2 Posts
