1 - 2 of 2 Posts
I am having trouble routing the rear antenna cable for my 1968 convertible. Can anyone help me with this matter.
Should go over the right wheel well then under the wire gutter along the inside rocker. To do it this way you will need to remove some of the interior. I just finished a restoration and used the hidden antenna that I attached to the heater box with the supplied 3M tape . . . . .works fine. Now if you have the antenna hole then this would not be possible. If you do not have an AIM then you might want to get one from one of the Camaro vendors.
1 - 2 of 2 Posts
