Removed my 12 Bolt in order to install 3.73 Posi Gears (now installed) and noticed the different position of the rear Disc brake assemblies installed by the PO. Left brake is in the forward position and the right brake is in the backward position. Is this correct and if not, what is the correct position? If not correct, is it a problem worth fixing? I would think they should both be in the forward position, but what do I know…...
