1 - 1 of 1 Posts
I found something cool thought I would share it.The rear disc brakes from a 2000 S-10 blazer bolted directly on my 68 rs 10 bolt rear end with only minor modifications like a .200 thousanths shim between the axle flange and the caliper bracket to locate it correctly.Also a new locating hole for the LR lower shock hole.All else was a bolt on including the brake line,and works excellent.A little mod.for the e-brake cables but not too bad.
1 - 1 of 1 Posts
