1 - 8 of 8 Posts
can someone tell me what rearend ratio i might have if i rev 3500 in 4th driving 60mph with a 4-spd saginaw? its a 67 L30/M20 coupe with 10-bolt rear... Thanks!
67 std/dlx coupe L-30/M-20, bolero red/parchment, vienna
S
Guest
to turn 3500 with a 1:1 tranny gear and 12" height from center of the rim to the ground you would have to have a 4.10 ratio in the rearend.
my 26" tall tires do 2800 at 60 with 3.70 gears. that's with a 4 speed, not an auto. no, i didn't get that from looking at my speedo- i used a formula in The Auto Math Handbook. 3500 would be in the 4.56 area, for me at least. taller tires will lower the rpm, shorter will raise it.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
I have 4.10's now with 26" tall tires, I will go out on the highway and see for myself. I could have sworn I turn more RPM than that (when not in OD). I had a car with 4.56's before as well and I know it buzzed pretty high. Mine is automatic, so I guess that could be the difference.
Royce
I have 255/60-15 in back...
thanks for the reply!
67 std/dlx coupe L-30/M-20, bolero red/parchment, project
I have 4.56's w 255/60's and turn 3900-4000 at 70 mph.Man does it buzz all the time.But they are great at the strip.
1 - 8 of 8 Posts
