Hey guys. Long time listener, first time caller. I'm a pretty good DIY'er, and I have a son who enjoys working on the car with me, but I need some guidance on what to buy.
69 camaro ss clone. Lots of original (at least date correct) parts. 350 SB is not original but rebuilt and runs great. Tranny is TH400. It has front disk brakes that are fairly new.
10-bolt rear, drum breaks, leaf springs that are completely flat.
My next project is to replace the rear end. I'd like posi-traction, disk brakes, 12-bolt and new leaf springs. I'm assuming I can just buy and entire rear end ready for install so what do you recommend? I'm not racing and don't want to spend 10K on a fancy aftermarket end. I think the original style parts will suit my needs just fine.
One area I may need to outsource is running brake lines to the rear. I'd also like someone in the brake business to make sure the current booster system is sufficient and to confirm my vacuum is adequate.
Only other comment is that my end goal is to put a ZZ6 in. I know this is a whole topic in itself but the point is more horsepower while staying in the small block class and keeping a/c.
Thoughts?
Thanks.
Thoughts?
Thanks.
