I posted something in wheels and tires but I figured it would be better here. here's the deal. I installed new hotchkis springs and after measuring I noticed the rear is a little more than 1/2" to the pass side...It may have been like this before so I can't say it's the springs. I installed the springs and left all the bolts a little loose then lowered the car and tightened. I did this 2 times so I don't think that could be it. I measured the perch to the axle flange and thats the same on both sides, the rear is correct. I measured the frame rail to the outer fender lip and thats the same. I don't know whats going on!!! Can someone help? If I am able to move it over 1/4" my wheels would fit perfect. On the pass side the wheel will be real close to the lip and 1/2 away from the drivers. So I need my 1/4...Help please...
If I installed something like this http://www.speedtech-performance.com/pdf/Offset_Shackles_install_guide.pdf for my 1/4" wouldn't that angle my wheels to one direction?
