Be sure to hang on to it! It's very tough to find original GM lamps without the wires cut. Also, the repops and the current GM NOS ones are subtly different than the originals. If you look at the holes in the 'feet' where the screws fasten the lamp housing to the bumper, the holes on the 67 lamps are centered. The holes on the newer ones are offset. The offset ones might be correct for a 69, but I don't think they are correct for a 67. The diffence is very noticable if you know what to look for. The color of the wire and the rubber grommet are not correct on a lot of the repops also.
